OVO JE OPREMA OVOG ROADSTERA, ZNACILO BI MI VASE MISLJENJE STO BISTE PROMJENILI NA NJEMU. JA SAM GA PRIJE DVA DANA UZEO, ALI BI VEC NESTO MJENJAO, NPR: ILI PREDNJI ILI ZADNJI MJENJAC, JER IZGLEDA VEC U PONEDELJAK MORAM DA DOSTELUJEM ZADNJI MJENJAC.
Ram: Alloy 6061
Vila / Amortizer: MODE - MD-682S
Šoljica vile: VP-A41AC - Aluminum semi-integrated, dia. 28.6/44/30mm, stack height 8.5mm, with cup: MD-1D
Uložci srednje pogona: THUN - ROCKY - 119 mm, shell: BSA 68mm
Srednji pogon: DOTEK - DK28-S391CP, 48-38-28, 170mm, W/ chainguard
Prednji menjač: SHIMANO - TOURNEY FD-TZ31 band-type31.8mm 48T top-pull, cs angle: 66-71
Zadnji menjač: SHIMANO - TOURNEY TX RD-TX35 6/7-speed direct attachment type
Ručica menjača: SHIMANO - ST-EF51 index front / 7 speed rear
Brzina: 21
Zupčanici: SHIMANO - multiple freewheel sprocket MF-TZ31 7-speed 14-16-18-20-22-24-34T brown
Lanac: KMC - Z-50 - 1/2”x3/32” (114 links) (7 speed)
Kočnica: LOGAN - JY-927AE - alloy die casting brakes, 70 mm hoe, silver
Ručica kočnice: SHIMANO - ST-EF50 V-brake levers
Glave: QUANDO - KT-A15F front black / KT-A11R rear black
Felne: KRIPTON - KRYPTON-X 622-19, 36H , EYELETING: NO, RDA: NO, GBS: YES
Pneumatici: RUBENA - 37-622 V 66 FLASH (700 x 35C) W/ reflector stripes
Lula: PROMAX - MA-525 - ext.: 105mm,A-HEAD, dia.: 25.4mm, angle:0~60 DEG,W/ PROMAX logo
Volan: UNO - AL-027T - alloy,W=610mm, angle 9 deg, rise = 30mm
Rogovi: -
Sedlo: SELLE ROYAL - RIO MAN
Zadnji amortizer:
Dostupne veličine rama: 28” X 21”, 28” X 23”
Težina bicikla: 14,5
CAPRIOLO ROADSTER TOUR
pocetnik983
, May 19 2013 07:36 AM
7 odgovora na ovu temu
Postavljeno 19 May 2013 - 08:08 AM
To je normalno sto treba da ga dostelujes. Suludo je da menjas delove na bajku koji si tek izneo iz radnje.
Bar ga malo izvozaj, pa onda pimpuj.
Postavljeno 19 May 2013 - 08:24 AM
Pozdrav, tourney menjaci ce raditi sasvim zadovoljavajuce barem godinu dana....Kao sto rece kolega normalno je da se menjac dosteluje posle nedelju dana....Na prvom servisu se bajk nasteluje a posle nedelju dana voznje se radi drugi servis jer se sajle istegnu pa je potrebno malko dotegnuti prednji i zadnji menjac i kocnice. ...
Postavljeno 19 May 2013 - 01:21 PM
O, bravo, pa ti si to kupio bicikl.... =D> =D> =D> Sa srećom!!!! Dugo da te služi!!!
Prekontroliši sve šrafove na bajsu, dotegni, žice na felnama takođe, našteluj kočnice, jer novi Capriolo bajsevi dolaze malo neutegnuti, pa ima malo zezanja u početku, ali ništa strašno kao i sa tim sajlama menjača....
Postavljeno 19 May 2013 - 09:16 PM
S obzirom koliko si spamovao po forumu i svaki dan otvarao po jednu temu za tvoju kupovinu, verujem da je svima laknulo ako si zaista kupio bajs.
