Suntour Epicon VS Rock Shox TORA
40 odgovora na ovu temu
#1 bluboki
bluboki
  • 438 posts
Postavljeno 22 September 2010 - 01:23 PM
Ok, trenutno imam dilemu.... sta kazete, Epicon ili Tora? Amortizeri su u klasi, cena im je prakticno ista....
Specifikacije:
SF9-EPICON RL
I.C.E. : Yes
Travel : 80 - 140 mm
System : Air / Hydraulic Remote speed-lock
Lower : Magnesium monocoque light weight design
Design : Leading axle / Disc only design
Dustseal : Metal inserted type
Leg Color : Matt black, Metalic silver, White, #8285
Crown : Alloy
Integrated HD : Semi-ID type / 44mm
Stanchion tube : Alloy
Stanchion tube finish : Gold anodized
Finish : Shot anodized (Black, Silver or #8285)
Right Side : Hydraulic remote speed-lock cartridge
Left Side : Air spring system
Steerer tube : Alloy
Length (w/o thread) : 255 mm
Crown race diameter : 30 mm
Wheel size : 26"
Brake : Disc (International standard type) V-Brake (Option)
Preload adjuster : Air pressure adjust
Note Reversible design lever for Remote speed lock included
Rebound adjusting: Yes
max. disc diameter : 185mm
TORA
- hod amortizera: 85-133mm
- težina: 2221g (4.9 lbs)
- ublažavanje: Motion Control
Available Springs Coil U-Turn
- podešavanje: External Rebound, Low Speed Compression, Lockout, External Travel
Steerer Options Steel 1 1/8", Aluminum 1 1/8"
- materijal: Forged 6061 T-6 Hollow Aluminum
- gornje cevi: 32mm, Steel, Chrome
Lowers Magnesium, Is Disc Mount
- opcije: Remote
- maksimalni prečnik rotora: 210mm
Ja sam malo vise na strani Epicona, nekako mi i lepse izgleda, i lepse zvuci, a i cini mi se boljim... Jer neki ga po pouzdanosti i kvalitetu svrstavaju dosta jacim od Tore
#2 stolegrom
Postavljeno 22 September 2010 - 02:48 PM
Na papiru, nekoliko prednosti u korist Epicona:
1. Gornje nogice 32mm anodizirane. RS je na svoju viljusku od 160eur stavio celicne nogice...neverovatno. ](*,) Pa Sun modeli od 70eur su takodje s alu varijantom. A mana celika je sto rdja + tezina...tu se dolazi do slecedeg.
2. Laksa viljuska. Misaxtr je spomenuo da je tezina Epicona oko 1795gr --> vs 2220+. Ne treba ti 5 iz matematike da uvidis razl. u tezini. n2:smiley-cool21
3. Dobijas rucicu za lock. Za Toru ces izdvojiti jos nekih 2500 iz dzepa. :-]*
4. Noviji model viljuske. Tore koje imaju u Capriolu su zalihe od ko zna kada...pa vidis da je covek kupio ostecenu. Ko zna koliko se je razvlacila po magacinima. n:fighting0027
Ponavljam, ovo je na papiru, licno nisam vozio Epicona. Dakle, treba uracunati i stvar licne preferencije. 8)
#3 bluboki
bluboki
  • 438 posts
Postavljeno 22 September 2010 - 03:59 PM
Sto se tice 3 i 4 nema sta da se brinem, jer pavleproma (od koga bih je uzeo) mi je i prijatelj, tako da tacno znam sta uzimam :D
#4 misaxtr
misaxtr
  • 3059 posts
Postavljeno 22 September 2010 - 06:25 PM
Epicon. S tim da je po meni sasvim dovoljno uzeti Epicon-a sa 100mm hoda.
#5 bluboki
bluboki
  • 438 posts
Postavljeno 22 September 2010 - 06:39 PM
Pa jedan jedini novi epicon koji ima u PB ima podesavajuci hod... :P
#6 pri3rak
pri3rak
  • 3504 posts
Postavljeno 22 September 2010 - 07:11 PM
Pa ako imaju jedan jedini novi to je kupovina koja ne uliva mnogo poverenja.Epicon je sigurno bolja viljuska, pa ako ti nije cimanje da sam juris delove kada im dodje vreme ti uzmi nju, jer koliko vidim na PB u vangarantnom roku (kao i inace u gro drugih slucajeva) ne mozes racunati, a u okviru garantnog bi ti verovatno vratili novac.
#7 misaxtr
misaxtr
  • 3059 posts
Postavljeno 22 September 2010 - 07:18 PM
Bice delova u Planet-u, licno sam u konsultacijama sa njima oko toga sta treba i sta bi bilo dobro imati u servisu za redovno servisiranje a i za vanredno ako se desi neki kvar i sl.
#8 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 22 September 2010 - 07:24 PM
I jedno pitanje vezano za viljusku.Dali u pb imaju model koji podrzava v brake.Ja planiram da je uzmem,ali ako nemaju sa pinovima onda moram da povecavam budzet odmah i za nove disc kocnice.
puno znoja,malo krvi
#9 misaxtr
misaxtr
  • 3059 posts
Postavljeno 22 September 2010 - 07:26 PM
Model koji je kod mene na testu ima i V-brake opciju, tako da to nije problem. Bice ih sigurno kada dodje sledeci kontigent
#10 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 22 September 2010 - 07:28 PM
Odlicno,posto sam ja skroz zadovoljan sa dobrim v brakeom,pa kontam dokle god ima pinova nemoram da se bacam u veci trosak.
#11 bluboki
bluboki
  • 438 posts
Postavljeno 22 September 2010 - 07:32 PM
Vorda nedao ti bog da uzmes onog Epicona sto je u Novom Sadu! :P
#12 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 22 September 2010 - 08:10 PM
Sto?Mada nisam planirao do proleca da menjam vilu.
#13 srdjoni
Postavljeno 22 September 2010 - 08:24 PM
Zašto? I mene zanima :D !
#14 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 22 September 2010 - 08:27 PM
ma lozi nas da mu nekupimo vilu ispred nosa :shock:
#15 nblexel
nblexel
  • 1137 posts
Postavljeno 22 September 2010 - 08:36 PM
možda ništa ne valja :mrgreen:
Haro X6
#16 Vorda
Vorda
  • 4577 posts
  • LocationZrenjanin
Postavljeno 22 September 2010 - 08:37 PM
IZELI GA MOLJCI OD STAJANJA. n2:smiley-sick011
#17 bluboki
bluboki
  • 438 posts
Postavljeno 22 September 2010 - 08:43 PM
Lehel ako mi nadjes bombera koji je ispravan za te pare odmah cu ga uzeti... necu ni 3 sekunde razmisljati! :P
PRESTANI DA MI DIRAS EPICONA! :D
#18 srdjoni
Postavljeno 22 September 2010 - 08:51 PM
A-u! Biće gužva ujutro ispred Planeta ako se Bluboki ne izjasni... :D
#19 bluboki
bluboki
  • 438 posts
Postavljeno 22 September 2010 - 08:53 PM
odmah sjutra idem po njega :P
#20 srdjoni
Postavljeno 22 September 2010 - 08:55 PM
:D Vidimo se tamo!
