MTB OPEN-4 SOT
38 odgovora na ovu temu
#1 slobodan
slobodan
  • 629 posts
Postavljeno 23 June 2009 - 06:13 PM
PROPOZICIJE
MTB OPEN KUP 4 TRKA - SOT 28.06.2009
START 10.00h
PRIJAVE OD 8.30-9.45H NA MESTU STARTA - JEZERO U SOTU
LOKACIJA - SELO SOT 10km UDALJENO OD SIDA PREMA ILOKU-HR, 7km OD BACKE PALANKE PREKO ILOKA-HR PREMA SIDU. TRKA SE ODRZAVA NA OBLIZNJEM JEZERU ODMAH NA IZLASKU IZ SELA.
SATNICA-
10.00h MALA TRKA 3-KRUGA
11.00h VELIKA TRKA 5-KRUGOVA
1-KRUG 5km , STALNO JE GORE DOLE SA KRATKIM USPONIMA I SPUSTEVIMA OD TOGA DVA JACA OSTALO NORMALNO I NA KRAJU OSVEZENJE - POTOK, DODUSE PLITAK ALI ZANIMLJIV.
STARTNINA - 200din -20kn
NAGRADE - MEDALJE ZA PRVU TROJICU I DRESOVI ZA PRVOG U GENERALNOM MALE I VELIKE TRKE.
OBEZBEDJEN SANITET I REDARSKA SLUZBA
OBAVEZNO NOSENJE ZASTITNE KACIGE
ORGANIZATOR NE ODGOVARA U SLUCAJU NEZGODA TAKMICARA I SL
POZZZZZZZZ :arrow:
#2 slobodan
slobodan
  • 629 posts
Postavljeno 24 June 2009 - 09:07 AM
sad sam stigao sa treninga staza je dobra 95 posto po utabanoj travi tako da nam ni kisa nista ne moze, ambijent prelep pored jezera, usponi kratki a jaci ali nista strasno bice ok a nadamo se da ce se kisa ispadati do nedelje.
#3 slobodan
slobodan
  • 629 posts
Postavljeno 24 June 2009 - 09:11 AM
verovatno imamo i rucak u selu, crveni krst dolazi, bice sve ok
#4 slobodan
slobodan
  • 629 posts
Postavljeno 25 June 2009 - 05:31 PM
EVO ZOVU LJDI IZ DALEKA HOCE DA DODJU TAKO DA CE SE TRKA ODRZATI I PO KISI DA BUDE SIGURNO, DA NEBI NEKO DOSAO IZ DALEKA PA NISTA.
DANAS SMO SREDJIVALI STAZU STO VIDITE NA SLICI I SAD IDE MNOGO LAKSE SUTRA JOS DA UDARIMO GLANZ I TO JE TO.
POZZZZZ
P.S. PA GDE STE KRITICARI :?: KOMENTATORI :?: AJDE MALO GURKE [-X
#5 madmax
madmax
  • 6 posts
Postavljeno 25 June 2009 - 05:59 PM
PA EVO JA BIH MOZDA DOSAO !POZDRAV!!
SAMO DA ZAOKRUZIM FINANSIJSKU KONSTRUKCIJU!!!
#6 prodzo
prodzo
  • 240 posts
  • LocationCacak
Postavljeno 25 June 2009 - 08:24 PM
Slobo davaj odgovore u vezi trke. Posalo sam ti mail!
NEVER GIVE UP....
#7 gamzzy
gamzzy
  • 3667 posts
Postavljeno 26 June 2009 - 07:17 AM
Vozite ovo bez mene. U Nišu sam, i tu ostajem do subote uveče. U nedelju sam zvanično mrtav n:smil42d2
#8 slobodan
slobodan
  • 629 posts
Postavljeno 26 June 2009 - 08:29 AM
prodzo sredio sam ti besplatan smestaj kao i prosli put
gamzi nemo da te nema da te bije maler ti to odvezes na leru i pokupi vanesu i ostatak ekipe
staza je dobra ja mislim i najbolja do sada zato je steta propustiti dobru turu
jos jednom za one koji dolaze iz novog sada najblize je preko b.palanke i iloka-hr jer je to samo 2km od granice-hr, a mozete ostaviti auto u b.palanci i bajkom do sota 7km...a ako ne onda okolo na erdevik-sid-berkasovo-sot.
pozzzzz vidimo se :arrow:
#9 prodzo
prodzo
  • 240 posts
  • LocationCacak
Postavljeno 26 June 2009 - 12:12 PM
Dolazak nam visi o koncu. Vozilo je u kvaru, ako se do ujutru ne popravi .... moracemo da propustimo ovo :evil: :( .... javljam ti sutra do 12 da li dolazimo.
Sve nam zavisi od djunte.
NEVER GIVE UP....
#10 markowe
markowe
  • 416 posts
Postavljeno 26 June 2009 - 06:33 PM
Pozdrav, samo da potvrdimo dolazak Novosađana - Gruja, Gordan i ja.
Verujem da će sve biti dobro, a spremni smo da vozimo kakvi god bili uslovi. Ovo vreme jako nervira, ali ako budemo čekali idealne uslove nećemo ni voziti ove godine. A u svakom slučaju ne može biti kao što je bilo na Stražilovu prošli vikend...!
Nego, jedna molba! Prošli put je spojena mala trka sa velikom zbog manjeg odziva, pa ako to slučajno bude potrebno i ovaj put, jako molimo da se velika trka ne pomeri ranije kao što je tada bio slučaj, jer mogu neki (mi, npr!) da izvise! Nama je Sot dosta dalek jer nemamo svi sređene dokumente pa nismo u mogućnosti da dođemo preko Iloka, a ne možemo da krenemo pre nekih pola 9 ili 9...
Move along now, nothing to see here...
#11 bmsradulovic
bmsradulovic
Postavljeno 26 June 2009 - 08:12 PM
zbog finansijskih problema i nama dolazak visi o koncu a ja ti obecavam da cu doci makar i bajsom :D
MTB!je*eno dobar sport!
#12 slobodan
slobodan
  • 629 posts
Postavljeno 27 June 2009 - 04:42 AM
PRVO MALA TRKA STARTUJE U 10h NEMA SPAJANJA A VELIKA OKO 11h PO ZAVRSETKU MALE ALI AKO TREBA DA VAS SACEKAMO NIJE PROBLEM SAMO SE JAVITE DA ZNAMO.
IMAMO I NOVOG SUDIJU MATIC ZORANA TAKO DA SE NADAM DA CE SVE BITI OK
KAZU SUTRA KAO I OVIH DANA MADA OVDE KISA NIJE MNOGO PADALA A STAZA MOZE DA SE VOZI BEZ PROBLEMA BLATA NEMA NIGDE KAO DA VOZITE PO FUDBALSKOM STADIONU TRAVA 95%
A ZA KRAJ SAM PLANIRAO KUPANJAC U JEZERU ALI TEMPERATURA NIJE VELIKA...
VOZIMO KISI U INAT [-o<
#13 markowe
markowe
  • 416 posts
Postavljeno 27 June 2009 - 10:27 AM
Hvala na trudu Slobo - vidimo se sutra. Bi li mogao još jednom svoj mobilni da okačiš da ti se jave eventualni kasnokasnioci? Mada ćemo se potruditi da budemo na vreme, naravno.
#14 slobodan
slobodan
  • 629 posts
Postavljeno 27 June 2009 - 01:10 PM
moj mob - 064/8633512
za sad nema kise i staza je u super stanju
pomozi boze..... [-o<
#15 markowe
markowe
  • 416 posts
Postavljeno 27 June 2009 - 01:38 PM
Hvala hvala. E, još jedno pitanje - da ne znaš kojim slučajem da li postoji neka prečica od sela Ljuba do Sota? Makar i bajsom da može da se prođe. Skratilo bi nam put poprilično a opet ne bismo morali preko Hrvatske.
#16 slobodan
slobodan
  • 629 posts
Postavljeno 27 June 2009 - 07:25 PM
ima precica 3km i tu ste ali je los put mozda moze i autom ako je malo vislji vi probajte a ako ne onda ga ostavite kod policije.
znaci izadjete iz ljube i do kraja 100m pre granice ima lenija levo 3km los put i 2km nizbrdo do jezera po asvaltu i tu ste, ako zapne vi se javite.
pozzzzzzzz
#17 vajs
vajs
  • 352 posts
Postavljeno 27 June 2009 - 07:44 PM
Eda, Dragan i ja krećemo bajkovima ujutru a ostali dolaze kolima! Vidimo se
www.nemanjavajs.com
www.novisadbike.com
#18 gamzzy
gamzzy
  • 3667 posts
Postavljeno 28 June 2009 - 12:36 PM
ja sam ustao iz kreveta posle 11h, tako da definitivno ništa od mene :mrgreen:
#19 markowe
markowe
  • 416 posts
Postavljeno 28 June 2009 - 06:08 PM
Evo, na kratko da se javim posle Opena na vrlo prijatnoj lokaciji akumulacije Sot. Kao i uvek, Sloba i ekipa su izdvojili vremena i truda da nam priušte jedan trkački ugođaj više ove godine. Kao i uvek, moglo bi se pohvaliti štošta a i požaliti se na ponešto, ali najveća zamerka ide na
slab odziv!!!
Ako vam kažem da sam ja (zamislite), uprkos tome što sam se lično dosta namučio na pomalo grbavom travnatom terenu, „ćornuo” jednu od medalja, onda vam je jasno otprilike kakav je odziv bio.
Šteta - ne znam da li je bila kratka najava, da li su svi na letovanjima, da li je kalendar prepun trka pa se ne stiže, da li je nekom „ispod časti” da vozi trku gde nemaju šanse da ugrabe ligaški poen (gde ste Hobisti?!), da li je Šid daleko...
Stvarno ne znam, svako će imati svoj razlog, naravno, ali mogu da kažem da oni koji smo bili cenimo još jednu priliku da odmeravamo snage u MTBu u jednoj Srbiji gde su prilike za to još uvek relativno retke (negde se trka svaki vikend, pa i češće), kao i da se družimo. A ako neko ima zamerke na organizaciju, mislim da bi svako pozdravio vaš pokušaj da i vi po vašem organizujete jednu Open trku u svom kraju.
Na tu temu, nešto smo pričali o tome da šaka Novosađana organizuje trku u seriji „Open” 12. jula (možda u Ledincima/Popovica, nešto na tu temu). To je sve daleko od izvesnog - zavisi od više faktora, ali sigurno ponajviše od interesovanja da se tako nešto uopšte održi.
Inače staza na današnjoj trci je bio poseban izazov po tome što skoro da nije bilo ravnih delova pa sam ja proveo celu trku debelo zadihan zbog jakih zakucavanja. Tu nije pomoglo ranije pomenuto grbavo tlo koje mene uvek ubije u pojam - što reče neko, maltene moraš i nizbrdo da pedaliraš! Bilo je i dosta trnja koje je trebalo vešto izbeći (što nije svima pošlo za rukom), i par zanimljivih spusteva, uključujući jedan malo duži i strmiji a i par prolazaka kroz potoke za koje su bili potrebni dobri zaleti! Inače, bilo je suvo-suvcijato (osim potoka!), kome je eventualno blato predstavljala prepreka da dođe.
Uglavnom, jedno trkačko iskustvo više, kome to nedostaje (meni svakako) i samo se nadam da masa nije odustala od ideje Opena jer mi se i dalje čini da ima velikog potencijala.
#20 slobodan
slobodan
  • 629 posts
Postavljeno 28 June 2009 - 07:01 PM
HVALA MARKOWE , KOLIKO CUJEM SVUDA DANAS NEKO NEVREME PA SU LJUDI MOZDA MISLILI DA JE I KOD NAS A INACE LOSE VREME SMORI COVEKA PA OSTANE KUCI ALI STA JE TU JE NAJUPORNIJI SU TU
A EVO I REZULTATA
MALA TRKA
1-156 BATORI MARKI BBK POZEGA HR 25.20
2- 22 BARNA MILOS OPEN SID 37.16
3- 17 VRCEK PETAR FANATIC N.S. -1 KRUG
VELIKA TRKA
1- 155 SKUZIN MATEJ BBK POZEGA HR 45.19
2-118 BARAC PAVLE RISCYCLING 48.39
3-158 JOJKIC DEJAN OPEN SID 49.26
4-157 VUJIC MARKO NOVI SAD 49.40
5- 200 RADOVANOVIC SLOBODAN OPEN SID 50.42
6-179 MARK DANIELS NOVI SAD 56.14
7-160 GORDAN GRDIC RISCYCLING -1 KRUG
ODUSTALI 185,161,199,184
JOS JEDNOM SE ZAHVALJUJEM SVIM UCESNICIMA KOJI SU SMOGLI SNAGE DA DODJU
NADAM SE DA CE BITI BOLJE :?:
