PILE [MTB] CAPRIOLO GTX
158 odgovora na ovu temu
#1 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
Postavljeno 28 December 2008 - 10:19 PM
Evo da se pohvalim znaci najzad sam i ja uzeo vrh bajs koji ce me nadam se strava sluziti! =D>
mozda sam trebalo da cekam do proleca ali me mrzi i pare su me svrbele ali mislim da sam
dobro kupio.sta vi mislite,bajk je GTX Capriolo sa ful suspenzijom znaci mogu sad kad dodje
prolece da vozim gde ocu ali BUKVALNO GDE OCU!!!sportski pozdrav svim! =D> :mrgreen:
Bicikl sa čeličnim ramom. Od ove godine sa novim dizajnom rama. Rekreativni full suspension bicikl za vožnju po blagim terenima u prirodi.
RAM
VELIČINA RAMA
Hi-ten
26'' x 20.5''
VILA
ŠOLJICA
LOGAN - LF 780
FP-H501 - 8 pcs headparts, thread: 1''X24T 22.2/30/27mm, W/key washer
ULOŽCI SR. POGONA
CRANCKSET
KINEX - BLEPS 2 - 122.5 mm, shell: BSA 68mm
LANHANG - LH3187, LD-YST, 48/38/28,170 mm, steel CP, W/ chainguard
PREDNJI MENJAČ
ZADNJI MENJAČ
SHIMANO - TOURNEY FD-TZ21 band-type 28.6mm 48T top-pull, CS angle: 66-69
SHIMANO - TOURNEY TX RD-TX31 6/7-speed, not rapid-rise, W/riveted adapter
RUČICA MENJAČA
BRZINA
SRAM - MRX Comp twist shifters index front / 7 speed rear
21
ZUPČANICI
LANAC
SHIMANO - multiple freewheel sprocket MF-TZ31 7-speed 14-16-18-20-22-24-34T brown
KMC - Z-50 - 1/2''x3/32'' (114 links) (7 speed)
KOČNICA
RUČICA KOČNICE
LOGAN - JY-927AE - alloy die casting brakes, 70 mm shoe, silver
LOGAN - JY-325PAE - die casting alloy lever with plastic clamp, 2.5 finger, for V-brakes
GLAVE
OBRUČI
QUANDO - KT-A15F front silver / KT-A11R rear silver
SW19SG 559-19, 36H, alloy double wall
PNEUMATICI
UPRAVLJAČ
CAMEL - 57-559 CB-531 (26 X 2.125)
LOGAN - 165/2.5-steel stem with alloy cap, dia. 22.2mm, ext:100mm, bar bore: 25.4mm, angle +25 °, finish: ed black
LULA
ROG
WADER - GWHB-02, ATB - steel, W=580mm, angle 15 deg., 22.2X25.4mm
STUB SEDLA
SEDLO
WADER - GWSPSTEEL25.4 - steel seat post 25.4x300mm long, W/O clamp
SELLE ROYAL - WOLF
PEDALE
ZADNJI AMORTIZERI
FP-906, PP body, steel cage, 9/16'', with balls, with reflector
LJ 400B 850 LBS/IN
DODATNA OPREMA
TEŽINA
18,3
to je to ukratko o delovima i samom bajku ako imate nesto pitajte jedva cekam da se otopi
led pa da vozim taman me je lepo prosla ruka od onda :D
#2 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
Postavljeno 28 December 2008 - 10:20 PM
ps nemam sliku jos nisam slikao bajk pa sam stavio ovu sa kaprijolovg sajta dok
ne uslikam moju novu bebicu pozdrav ljudi =D> :mrgreen:
#3 arioth
arioth
  • 2939 posts
  • LocationMagnitogorsk
Postavljeno 28 December 2008 - 10:26 PM
Auuu neko ima los kosmar. Malisa izadji iz fantazije i udji u realnost :mrgreen: :mrgreen: :mrgreen: :mrgreen:
#4 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
Postavljeno 28 December 2008 - 10:38 PM
Brate ne znam sta ti ovo znaci ali si mogao to da napises malo blaze a ne ovako ispade dame napadas
a neznam zasto,jer sam ja reko da cu taj bajs da vozim gde ocu bukvalno po svim terenskim
preprekama jer bajs ima 2 suspenzije i sta sa tim sad nije u redu objasni mi???
#5 arioth
arioth
  • 2939 posts
Postavljeno 28 December 2008 - 10:45 PM
Brate, vidi brate. Ja sam se malo salijo brate, znas ono brate sala. Nemoj da se odma nerviras brate, ali realnost je brate da ta tvoja dupla suspenzija brate i nije nesto narocito brate. Mislim da me razumes brate. A ako ne brate ostani CRN
Postavljena slikaPostavljena slikaPostavljena slikaPostavljena slikaPostavljena slika
#6 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
Postavljeno 28 December 2008 - 10:47 PM
brate nisis se salio ali ajde nemam vremena da se zaglupljujem sa svima tu ko oce da da komentn normalan oce a ko nece bash me briga nemora ni da pise,aj putuj gumane dalje,okani me se! =D> [-X
#7 mixitron
Postavljeno 28 December 2008 - 10:48 PM
Pile, ti si bog izgubljenih slučaja.
Ali bog.
=D>
#8 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
Postavljeno 28 December 2008 - 10:49 PM
Ali bog.
=D>
nadam se daje ovo barem sala =D> :wink:
#9 arioth
arioth
  • 2939 posts
Postavljeno 28 December 2008 - 10:51 PM
Mislim da stvarno su trebali da ti daju jednu od uloga u seriju LOST
#10 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
Postavljeno 28 December 2008 - 10:53 PM
pre bi ti prosao kasting dileo ne znas nista pises a tu samo vredjas kako stignes
vise ne odgovaram na tvoje maloumne prozivke brate okani me se lepo sam ti rekao idi vise!
#11 biciklista
biciklista
  • 63 posts
  • LocationBeograd/Zvezdara
Postavljeno 28 December 2008 - 10:55 PM
:shock:
Ma masina je super sta napadate decka... :D
#12 arioth
arioth
  • 2939 posts
Ej chicken gde si procitao da te neko vredja. Vidis da su to samo sale. :mrgreen: :mrgreen: :mrgreen:
#13 Ciklo
Ciklo
  • Administrators
  • 3853 posts
  • Location-= BGD =-
  • Bajk:Pinarello/Trek
Postavljeno 28 December 2008 - 10:57 PM
nek je sa srecom n:bicycle
#14 dare986
dare986
  • 101 posts
  • Location.:.Krusevac-Nis.:.
Postavljeno 28 December 2008 - 10:58 PM
VIdim ja bice ovde svasta :roll:
I close my eyes, only for a moment, and the moment's gone
#15 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
pa brate znam da su sale ali si priznaj bio malo vise grub i direktno si napao a to ne volim
ajde kul prihvatam salu ali pazi dobro u buducnosti sta pises i kako mene su tako hteli da
lincuju sa foruma jer sam previse direktno reko sta sam imo!
ps biciklista havala na lepim recima pozz =D> =D> =D> :mrgreen:
i ciklo mod takodje =D>
#16 mixitron
Postavljeno 28 December 2008 - 11:03 PM
Nije, nažalost. Pričao tebi ili zidu, na isto izađe. Posle ovog se svi oni koji su ti dobronamerno pisali i ukazivali na ovo ili ono verovatno osećaju blago glupavo.
Strava ti je bajk. Samo mu skini tu nogicu.
#17 arioth
arioth
  • 2939 posts
Postavljeno 28 December 2008 - 11:06 PM
Zavisi sta si hteo direktno da kazes. Ja samo lepo sam se salijo na tvoje namere da vozis taj bajk ''svuda''. Ipak treba da saslusas savete starije pre nego nastradas. Ovo nije bajk koji moze da ti pruzi mnogo toga i ima veliku sansu da ti otkaze poslusnost. Zato sada kada budes na raspustu uhvati se malo ''motike'' u ruke i nabaci nesto para i na leto da kupis nesto bolje
#18 arioth
arioth
  • 2939 posts
Postavljeno 28 December 2008 - 11:09 PM
Nisi mogao direktnije da mu napises
#19 mtb_pile
mtb_pile
  • 346 posts
  • Locationbeograd
Hvala na lepim recima,i da nogica je vec skinuta,da da,pozdrav! =D>
nemam vise para kozna kad cu imati ali jednog dana planiram da kupim nesto dobro no
otompotom,videcemo,a kako mislis da otkaze poslusnost pukne ili sta?
#20 Hari
Hari
  • 1921 posts
Postavljeno 28 December 2008 - 11:12 PM
Napadoste coveka ni krivog ni duznog :D Kad bih pitao sta ste vozili u piletovim godinama tesko bi se ko pohvalio 8)
