Italija - Južni Tirol mart 2025.
italija roadbiking spring 25 cycling alphs biciklizam proleće planiranje južnitirol
7 odgovora na ovu temu
#1 _Sanja_
_Sanja_
  • 4 posts
Postavljeno 27 August 2024 - 11:47 AM
Pozdrav svima,
Planiram na proleće, negde u martu 2025. godine da vozim rutu koja ide kroz Južni Tirol, Bolzano i druga mesta, do Verone. Na ovom linku postoji detaljni opis rute: https://www.komoot.c...ugh-south-tyrol. Ne bismo sasvim pratili ovaj tempo i vozili bismo više od 2 sata dnevno u proseku.
Ispod ove poruke je narativni opis rute, a prilažem i mapu.
Ja sam inače iz Lazarevca, ali radim i redovno boravim i u Beogradu. Ne vozim redovno, ali mogu da izvezem i dugačke deonice. Često putujem u inistranstvo zbog posla i navikla sam da vozim biciklu svuda.
Volela bih da mi se jave zainteresovani ljudi, Uslov je da mogu voziti oko 50km dnevno, da imaju iskustvo vezano za Italiju i putovanje u druge strane zemlje, kao i da nisu takmičarski nastrojeni i opsednuti tehničkim stvarima.
Bicikle bismo preneli Flixbusom i vozom.
The Adige Valley Cycle Path is 300 kilometers (186 miles) long and runs from Reschen am Reschensee, from where the Adige river springs, to Verona, which lies about 100 kilometers (62 miles) to the south. The well-constructed cycle path with its views and smooth asphalt will make every cyclist's heart beat faster. It undulates ever more downhill until shortly before Verona—and leads you past some beautiful cities, such as Merano and Bolzano. Most of the time the long-distance cycle path runs parallel to the Adige river. Shortly before reaching the end of the Tour, the route gives in to the surrounding hills, giving you a fantastic view of the Adige valley. Along the cycle path, you'll find ample accommodation, rest and refreshments, as well as public transport, seeing as the Adige valley is a popular holiday region in South Tyrol.
#2 vidak
  • 4746 posts
Postavljeno 27 August 2024 - 08:30 PM
U to doba godine tamo najbolje ti je motornim sankama
  • 7
#3 Smasher
  • 3339 posts
Postavljeno 03 September 2024 - 11:40 AM
Haha, Vidak kao i uvek deli samo korisne savete. :D
#4 omega
  • 3549 posts
Postavljeno 03 September 2024 - 02:57 PM
Ово ме подсети на ону девојку која је тражила дружбеника да се воза с њом од Новог Сада до Београда...
#5 Banditosi_Cikloture
Banditosi_Cikloture
  • 68 posts
  • LocationNovi Sad, Vojvodina, Srbija
Postavljeno 16 September 2024 - 07:07 AM
Sanja,
Ne bih da nešto mračim, ali mislim da je mart jako rano za ovu vožnju, naročito za prvih par etapa dok se ne spustiš u malo niže krajeve.
Moraš uzeti u obzir da su tu okolo sve vrhovi koji su preko 2500mnv (poneki čak i preko 3000mnv) i da to utiče na mikro-klimu cele regije. Iskreno, preporučio bih ti da mesec maj bude početak razmišljanja za ovu vožnju. Realno tu skijaška sezona traje sigurno do aprila, a ako je godina dobra, često i duže. Ti se u principu sve vreme spuštaš, pa nećeš imati prilike da se pristojno zagreješ, a ako je napolju još i hladno (što je za očekivati), neće vožnja biti prijatna.
Inače BRAVO za izbor rute, tuda sam do sada prokrstario desetak puta (što kolima, što biciklom) i predeli su stvarno fenomenalni.
Bilo kako bilo - SRETNO!!!
Postuj po koju sliku kad završiš vožnju, da i mi malo uživamo...
Pozdrav,
D.
Biciklističke priče na blogu: https://cyclingisway...e.blogspot.com/
#6 _Sanja_
_Sanja_
  • 4 posts
Postavljeno 27 April 2025 - 01:46 PM
Hvala svima koji su odgovorili :)
Ne mislim da je mart bio baš preran za ovu vožnju, mada pošto je ove godine vreme bilo loše, ipak nisam to vozila u martu.
Elem, ideja ostaje, tako da onda šta mislite, kada je najbolje to planirati? Koje doba godine?
Pozdrav :)
#7 vidak
  • 4746 posts
Postavljeno 27 April 2025 - 09:51 PM
Čim se istopi sneg
#8 _Sanja_
_Sanja_
  • 4 posts
Postavljeno 29 April 2025 - 02:56 PM
Ovde je ruta sa iskustvima: https://www.komoot.c...ugh-south-tyrol
Ja bih koristila kombinaciju Flix busa i voza da prenesem biciklu.
Definitivno mislim da je je početak juna bezbedan, ali može da bude nezgodan ako bude mnogo vrućina. to je drugi problem.
Moguće da se ja odlučim i sama da idem ako mi obaveze dozvole.
Also tagged with one or more of these keywords: italija, roadbiking, spring 25, cycling, alphs, biciklizam, proleće, planiranje, južnitirol
